need to turn boat upside down any advice
Dougieloo@aol.com
Post by Dougieloo@aol.com » Sat Oct 27, 2018 6:42 pm
Need to turn my volga 70 upside down to clean and put liner on any body have any tips on doing the turning
thank you
olaf
Re: need to turn boat upside down any advice
Post by olaf » Tue Oct 30, 2018 4:55 pm
Hi Doug,
why do you want to turn it? As I painted my boat last christmas I took europallets under the foils. So I could work anywhere at the boat and I only had to use a pallet truck and two racks with flooring sleepers.
Otherwise, if you realy need to turn the boat buttom up it is possible to do it with endless hoisting slings. But it´s heavy work I think.
Best to you
olaf
Dougieloo@aol.com
Post by Dougieloo@aol.com » Wed Nov 14, 2018 6:04 pm
thanks Olaf
we have removed the foils and am going to spray a 3 mil. flexible polyurethane liner /membrane on the exterior below water line
my boat is 47 years old it has arias of corrosion
over the years i have had problems with the hard paint popping around the flush rivets also rivet heads popping off after corrosion between the rivets and the hull
having a break in the membrane were the high speed water would hits around the foil mounting points would lead to possible water getting under the membrane and it pealing
it is very important to have the bare metal surface properly cleaned and prepped and the membrane sprayed evenly in a smooth method cleaning and prep in the stepped arias will be difficult at best
we well be applying an etch 2 part primer and adhesion coats be for the flexible membrane also
we have done some small plate replacement on the bottom in 2 arias and hope to also accomplish incapsulating these repairs to minimizing possible corrosion
we think we have a solution to role the defoiled boat [no engine]over using the travel lift as the slings can be shorted on just one side of the lift easing the boat over bottom side up
BUT STILL WOULD WELCOME ANY IDIAS ON THE ROLE OVER
On the hard stand interior cleaning before interior etch epoxy
New hydraulic Jâck plate for new 140 Suzuki out board motor
Hull repair bottom plate rib repair from low riding inboard outboard Brovo one gimble new plate for out board motor bracket
Bottom plate replacement weld in
Transom refit for our board Jâck plate
Bottom plate prep for repair weld in
Start of interior below water line wire brush sanding before etch epoxy primer
Engine rib rebuilt
Gimble repair old exhaust repair
Interior picture after pressure washing
Post by Mark » Thu Nov 15, 2018 11:26 am
I would be scared to roll my volga over..
The overhanging deck will bend easy.
But indeed a 2K paint is hard, and can crack quickly.
the only tip/hind i have is to do it slow and careful.
Good luck!
Dougieloo@aol.com
Post by Dougieloo@aol.com » Tue Nov 20, 2018 3:43 pm
thank you well do
olaf
Post by olaf » Sun Dec 02, 2018 9:35 am
Wow, that is a project with much work. Here is a link with pictures. This is the behavior I would try.
http://aw-marine.com/tag/boot-drehen/
At the floor old tires and then so as Mark say, carefully and bit by bit with long hoisting slings and a crane.
Good luck and thanks for the picture of your jack plate. How long is it behind the transom?
Dougieloo@aol.com
Post by Dougieloo@aol.com » Fri Dec 07, 2018 4:33 am
22 inches for the jack plate the nice part is it can be lowered or raised at full power to maximize efficiency
thank you we are going to use the boat lift the straps can be lifted from just one side rolling
the de-foiled hull slowly over ... we hope !!
Post by Mark » Mon Dec 17, 2018 9:14 am
A bare hull is not that heavy, almost to do by hand ;-)
Dougieloo@aol.com
Post by Dougieloo@aol.com » Fri Jun 21, 2019 5:57 pm
thank you every one i got it upside down and siting on the boat trailer with a small crane flat deck truck who brought the boat home from the boat yard
as they were crooks and doing poor work padding hours and charging more than the agreed hourly rate
in the process of building a shop/ garage 26 ft wide 42 ft long with to I beams with a lifting capacity of 5 ton apiece 13ft clearance under the beams and hope to be back to work on it in about 2 months
https://www.volga-hydrofoil.net/phpBB3/ ... iew&id=736
