Propeller of the Volga 70 with GAZ53L engine
Posted: Mon Oct 08, 2012 10:42 am
I have put my boat to water and am testing it since 6 weeks. Unfortunately the test runs were not very satisfactory, as we found ourselves lurking around with approx. 10 knots at max 2600 rpm.
During the rebuilding of the boat, we made following changes:
Hull:
- we added a stainless steel patform for waterskiing purposes at the back, weight approx. 50 kg.
- we added an anchoring hide-away (Chrome box) on the bow, weight with anchor 15 kg.
- we made a wooden deck with a new wooden hood for engine compartment, and a box or convertible seat extra weight approx 100 kgs.
- we changed the seats from alumininium to wood, extra weight approx. 80 kg.
- we changed the aluminium tent pipes with stainless steel, extra weight ca 10 kg
- we changed the dasboard, extra weight approx. 15 kg.
- we changed from single big battery to double small batteries, extra weight approx 20 kg
Total: approx 290 kg.
Engine:
- we reconditioned the engine full with replacing new liners and new pistons, gasket, pump and reconditioned coolers.
- the engine block was machined down at the vicinity of the cylinder head by 1 - 2 mm, which resulted in a higher
compression of 7,6 bar (The old compression per book is 6,9 bar). Estimated power increase 5%
- As 76 Octane Gasoline is not available, we use 95 Octan. Estimated power increase 10%
- We exchanged the old distributor with a new high voltage one, which sparks with 35.000 V instead of 3.000 V. Resulting in better
ignition and better carburation of the fuel. Estimated power increase 10%
We could not measure the power increase, but estimate that we have been able to increase the power to 112 HP at 2800 rpm.
Wings:
Where cleaned and polished
Propeller:
Was cleaned and polished. The workshop has ballanced propeller and corrected some bends on the blades (?) according to the blade
which seemed to be most untouched.
Result:
The extra weight of approx. 290 - 300 kg is an issue, however if you consider that we drove only with 2 persons on board, it should be like as if 6 would be on board. During the test, we had also only a 1/4 tank full only. The engine was unable to rev-up to 2800 rpm and stayed at approx. 2600 rpm max. The speed couln't be measured but was estimated with 10 - 13 knots only. The spark plugs taken out
show, medium brownish color, which should indicate a good carburation. Buy best cheap Rolex Replica watches online, top swiss watches.
Possible mistakes:
- The extra weight is too much and the boat reacts very sensitive on this! (But how come, that you can see a boat with
original configuration running with 6 persons (480 kg) onboard approx 30 kn? We have +300 kg and 2 persons (+180 kg)
which is same?)
- The propeller was not put in original condition and the pitch was increased by the workshop (?).
Does anybody know the original propeller pitch of the GAZ 53L, V8 4,3liter engine? So we can remeasure it,
before trying to give it a lower pitch?
Hull:
Engine:
Wings:
Propeller:
Result:
Possible mistakes:
which is same?)
