Hull
Posted: Sat Jun 11, 2016 9:38 am
by Bren
Has anyone had experience with replacing rivets
Re: Hull
Posted: Sat Jun 11, 2016 2:53 pm
by Volgovod
I am
Re: Hull
Posted: Sun Jun 12, 2016 2:02 am
by Bren
I need to replace rivets randomly around the hull any information or tips would be appreciated
Re: Hull
Posted: Sun Jun 12, 2016 2:05 am
by Bren
Has anyone had success or knowledge with welding up holes.type of filler wire to use and sheet alloy type
Re: Hull
Posted: Sun Jun 12, 2016 3:44 pm
by Volgovod
Use welding impossible. Between the sheets of the hull in the seams of the padded gasket fabric. From welding it will burn. appears leak. Rivets of aluminum brand AMG-5 (АМГ-5 in Russian)Before application they must be heated above 150 degrees. After that, they will be soft for a day or two.
Re: Hull
Posted: Mon Jun 13, 2016 10:56 am
by Bren
Thanks for the info on the rivets.the hole are in the middle of a section with no lap seam would this be possible
Re: Hull
Posted: Mon Jun 27, 2016 9:45 pm
look into aircraft building. same technic..
Did 300 rivets in a volga of a friend,and 600 in my own volga(strela).
Re: Hull
Posted: Sat Jul 02, 2016 1:09 am
by Bren
Thanks mark would you be able to help me with with suppliers of rivets
Re: Hull
Posted: Sun Jul 03, 2016 8:32 pm
hay Bren,
You are in Australia right??
I was Captain on a Russian(Ukraine) hydrofoil in the Netherlands.
We did or own repairs,and got some rivet from the ship yard where they were build.
I'm going to my Volga tomorrow,and will check the bags for info.
There are some "foreign" rivets in my crate....
I will PM you on Facebook..
