Needing information on the foil to ? Anti corrosion mounted transistors
Dougieloo@aol.com
Post by Dougieloo@aol.com » Sun Nov 17, 2019 4:18 pm
I am look for some info on the Transistors that attached to the foils I have measured the OMS AT 25 some of the questions I have a are
1: how many Transistors are there per foil one for foil or two per foil
2: I know that one of the leads attach to the foil bolt but not sure we’re the other side attaches to. Any pictures
Picture of original foil anti-corrosion Transistor
would be great or any information
3: can I use a new style Transistor compared to the old original style transistor picture of the original transistor below
Re: Needing information on the foil to ? Anti corrosion mounted transistors
Post by Mark » Thu Jan 30, 2020 8:55 pm
euh i have never seen this..
I followed the specs from the Volga manual I found online.
Dougieloo@aol.com
Post by Dougieloo@aol.com » Thu Feb 13, 2020 8:16 am
hi Mark thank you this is the original they came with the boat
Post by Mark » Wed Feb 26, 2020 10:43 am
This is what I used as guideline.
and with magnesium not Alu anodes.
Dougieloo@aol.com
Post by Dougieloo@aol.com » Sun May 17, 2020 12:22 pm
Thank you Mark
So do I attach a wire between the magnesium sacrificial zinc to the ss foil using the 25 OM transistor ??
Another Question would be is there one transistor per foil or two there is two mag. Sacrificial zincs per foil mounted in the magnesium hull and then another 2 sinks of some kind mounted on the the foil it’s self any hint as to the type of sink that is attached to the Ss foil ?
