2 more weeks, and I will have it back in the shop for final assembly. The main colors and striping are on, and we are finishing the graphics. The interior was done by a famous car designer, and looks amazing. I just hope that after all this work, it is water tight! The boat was a complete disaster when we got it from Latvia, and it has taken way longer than anticipated to finish up. That said, it is going to be a gem.
I do have a question. I have re-powered the boat with an American V-8 set up to mate to the Volvo outdrive. I have no idea where to start with propeller selection (diameter/pitch). All ideas welcomed.
Adam
Almost out of paint booth!
pitts12driver
- Volga Vintage Racer Starboard.jpg (30.43 KiB) Viewed 164527 times
- Volga Vintage Racer Deck.jpg (36.49 KiB) Viewed 164527 times
Re: Almost out of paint booth!
Hi Adam,
Your Boat looks great as a design.
I am curious how it will turn out in reality.
Post pics.
As to the engine - prop combination, pls post some data of the engine like a dynochart or at least Max. HP and Torque at given Rpm.
Than one could form a notion and try to give some recommendations.
The Volga was designed to reach 32 knots as cruising speed. anything above this is just peak speed for a brief moment at calm sea and you will need additional
foils if you should ever plan to speed above 40knts./ acc. to Russian Volga sites and Holland sites too./
Go to the engine section of the forum.
Very good posts by different members.
Post pics.
