Volga 275
Posted: Sat Jan 28, 2012 9:17 am
by Klas
Hallo
I found this picture does anyone know what it is?????? Looks like a volga 275 without foils.
My volga is sleeping under a layer of snow.
Coastguard volga
Re: Volga 275
Posted: Tue Jan 31, 2012 11:40 am
If i think really hard..
Its Russian,and their cal is seagull....
I looked around on a Russian Volga forum and saw few pictures
of it.
Re: Volga 275
Posted: Sun Feb 05, 2012 7:31 am
by Klas
Thank you very much
Can you post the adress to the russian website
Do you know dimensions engine what they cost
I really like it
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: Volga 275
Posted: Tue Feb 07, 2012 10:03 pm
Hay Klas,
Since i was lost when i saw the winged boot..(
http://forum.katera.ru/index.php?/topic ... h-kriljah/ )
above link is the Russian forum..
It took me a while to find it.
I remembered it was a discussion on the urrp-25 gearbox used in the strela's.
I guy build a urrp-20 gearbox in his volga.
![Кардан НИВА.jpg (356.16 KiB) Viewed 37183 times urrp-20](./download/file.php?id=554&t=1&sid=87185e50213f1d8ebeab7143642e5401)
- urrp-20
I think that 1 was also used in the winged boot.
a little google ( and translate )
http://translate.google.nl/translate?sl ... 86&act=url
turns out I was wrong about the name..(maybe a nickname??)
anyway here it is..
Two more...
http://translate.google.nl/translate?hl ... 0006663139
http://translate.google.nl/translate?hl ... zh_1516241
Re: Volga 275
Posted: Fri Feb 10, 2012 11:38 am
by Infineon
Klas wrote:Hallo
Coastguard volga
It is boat "Strizh" 1390 project
http://forum.katera.ru/index.php?/topic ... re-strizh/
Re: Volga 275
Posted: Mon Feb 13, 2012 5:18 pm
haha
Hay Infineon.
I see the photo i used from the forum.. was your boat!!
Was I correct that u build in a Strizh gear box in your volga?
and if i read it right i must put a 75W90 oil in the urrp 25?
and is the same oil used for the "smal" v-drive?
Mark.
Re: Volga 275
Posted: Tue Aug 19, 2014 1:12 pm
behind this link you will get information about the "Strisch". It was used in the former GDR.
http://www.ddr-binnenschifffahrt.de/fot ... chiffe.htm
By the way, that ist an interesting side and there are some pictures of volgas.
