gaz 66
Posted: Sat Jun 05, 2010 2:17 pm
by ginge
can you tell me the firing order of the gaz 66 engine v8,and which cylinder is no.1
Re: gaz 66
Posted: Mon Jun 07, 2010 11:59 am
by christian tabakoff
looking from the flywheel /back end/ side of the engine : the right cylinder bank consists of cylinder 1, 2, 3 and 4 , Left bank - N 5,6,7,8.
Cylinder N 4 is on the right side just in front of the flywheel. N 1 is at the front end of the engine./if you have a truck, than cylinder N 1 is behind the radiator and fan./
firing order: 1-5-4-2-6-3-7-8. as on all Russian V 8 engines./ same as gm V 8 and Mercedes 420/
![Wink :wink:](./images/smilies/icon_wink.gif)
