gearbox v-drive
Posted: Mon Oct 14, 2013 8:04 pm
by rmw
does anybody has some information about this v-drive unit?
It is located in the middle of the passenger compartment. it is used in this typ of volga where the transmission ist mounted behind the engine and not inside the passenger compartment.
I need some information about max. rpm, angle between the two drive shafts and so on.
Thanks for helping me
regards
Richard
Re: gearbox v-drive
Posted: Thu Oct 17, 2013 1:05 pm
by Mark
Hay Richard,
I was looking in my info but most is of the one with gearbox,i have one of those..
But the angle is the same 12 degree if I'm correct.
On Russian forums i see them replaced by ZF drives...
http://forum.katera.ru/index.php?/topic ... h/page-154
I hope this info will help you.
Re: gearbox v-drive
Posted: Mon Oct 21, 2013 6:49 pm
by rmw
The original gearbox-angle is 12°?
Re: gearbox v-drive
Posted: Wed Oct 23, 2013 10:00 am
by Mark
I am sorry Richard,
I was wrong..
12°is measured from the base line.
that is the line over the keel of the boot.
I had to dig deep. but i found it.
It's 18°..
[img]
[/img]
sorry for the inconvenience
Regards Mark
