Volga Rubber Bumpers
Posted: Sat Mar 19, 2011 5:45 am
by pitts12driver
I finally finished my boat. It looks amazing. It's out having a trailer built at the moment. Should be back home in 3 weeks.
I had a die made to extrude the rubber bumper that runs around the side. It is an improvement, as I designed it so you can install it in one piece that wraps around the bow - so you don't need that metal part to cover the joint. I am attaching a small picture of the bumper from the side as it is installed on my boat. I have enough for several boats if people are interested. -- Adam
Re: Volga Rubber Bumpers
Posted: Sat Mar 26, 2011 5:28 pm
by Klas
What dimensions inside and outside in mm please
best regards Klas
Posted: Wed May 11, 2011 10:38 am
by Daan
Hey Adam,
that's super! Your boat looks stunning. i would like to buy the rubber if you have anything left. Another qusetion: Im searching for a trailer, but is is extremely difficoult. I think i will need a custom made one. Is you trailer finished? how does it look like? Do you have pictures ore drwaings? Was it expensive to built? Are you allowed to drive with it on normal roads?
greetings,
daan
